Hi all,
I have a '85 F4 (R4 van) which currently has a max speed of only 95kph!!:eek:
I've recently changed the plugs, points, leads, dist cap, fuel pump and gave the carb a full cleaning.
The car starts & runs fine, idles fine, does not pink or misfire but just goes really slow in top gear..whats the problem??
I guess it may be the plug and points gap - can someone confirm please?
Its an 845cc-i think(B1BD7/07) with a Ducellier distributor(R287D83) and is not covered by the Haynes manual so not sure what the gaps should be.
i fit new Renault plugs straight from the box, gap was 0.8mm which seems a bit big. Points are set to 0.4mm.
Any help is greatly welcomed - Thanks
