billythefish
I changed the engine oil today and that was no problem, I then went to change the gearbox oil ( 4 speed ) which I did after a good long run and only managed to get around about pint of oil from the gearbox when in fact it should hold around two and a half pints.
Anyway, I jacked the car up at the back to try and empty the gearbox and then at the opposite side at the front, but all that came out was around a pint.
I then decided to fill the gearbox standing the car on level ground and all it would take was around a pint of oil before it started dripping out, now according to my manual the gearbox should take around two and a half pints because it is a four speed box?
Has any one any idea why this has happened.
:shock::shock:
:shock::shock:
