Keeping it simple
I'm not sure 'keeping it simple' is the right heading for this reply, because if we were interested in that, why would we mess about with old Renaults, let alone convert them into 3 wheeled specials?
However, before going down the path of doubling up on the anti roll bar, what does anyone think of reducing the mounting compliance by incorporating some polybushes?
I think the inner mounts would probably be catered for by a pair of these
http://www.superflex.co.uk/datasheets/Universal_ARB_mounts.pdf
so fairly easy to try that first, although replacing the outer FARB rubber would take a bit more thought.
I've just fitted some AVO's to the front of my car after seeing Steve's post about what a difference it made, and I might try polybushes next if I still have a lingering roll stiffness issue myself (although there are 16 'clicks' of adjustment to play with first, which at the current mileage addition rate for the 'Rundown Races Special' will probably take until well after Xmas to fully assess)
One final point that I'll post on here in case anyone else is mad enough to build an R4 based trike and has similar issues. I phoned Keith Hamer, the 'K' of DRK the other day, and he was good enough to spend some time discussing the straightline stability issues Steve has mentioned and I've experienced. He basically said that the suspension was fitted in standard form (R4 or R6), with no modifications, and tracking was set to 'toe out' as per specs. Some kitcar reviews of the DRK do mention a front suspension mod to improve stability, but Keith said this never actually happened, and stability was never a problem. I have tried going to 'toe in' tracking recently and that does seem to have reduced the tendency to wander slightly further
The DRK page on Keiths very interesting website is
http://www.scholar-racing96.com/drk.htm
I have tried contacting the DRK owners club for info on any mods any owners might have carried out, but so far no reply
best regards,
Andrew
