I bench bled it but no difference. So i thought i better change the front wheel cylinders out but the ones i got were not correctly manufacured for the model I stated. They were impossible to mount. They offset angle was out but about 20 degrees. So i cleaned up the old ones and transferred the pistons seals boots. What i found in the old cylinders was a lot of rubber muck, like a lot and on one side it was in the cavity where the brake hose enters. I suspect these hoses have broken down on the inside and that is where the rubber has come from? I can get one side to gravity bleed now but not the other(front). I will try bleeding with some help tomorrow but will have to order hoses now. The ones on their look really tidy which is why i didn't order with the other earlier orders from the UK.
