Yesterday I was returning from a long motorway drive in my R4 GTL when suddenly the engine stopped with the usual metallic knock you get when something nasty happens to a motor.
I have just had a look and can see through the oil filler cap that the valves are moving, as is the distributor so not timing chain. Also, with the car in gear turning the key drives it forward. Out of gear the starter motor turns freely as if there is no compression on any of the cylinders.
Could this be a broken crank? If so is there any point in attempting to replace it or will the engine be beyond it?
