C-pillar finishers
angel
Athens, Greece
I' m looking for a decent pair of C-pillar snap-on finishers, the bow shaped ones located between the rear door and the triangular window. Thanks!
Hi Angel.
I have one body for scrap
Can you send picture how much c pilar do you need so i can cut it in right lengh.
Thanks Hrvoje
What I need are parts 04 28 210 900 and 04 28 211 000; these are in fact detachable trim pieces even though they appear to be part of the C- pillar. If you can lever them off carefully it will save you from cutting, if you think cutting the pillar is easier, no problem.85.65.jpg
I am not sure that my GTL scrap body have that. :dontknow:
It is trim piece, as i understand it now? Or is that C pillar behind rear doors and infront of rear side glass
Here is body that i am taking parts off.
It's a trim piece but as it's painted in body colour, it's easy to think of it as a body part. It's located in front of the quarter window and behind the rear door window.
BTW, are you going to scrap the chassis as well?
Now that you pointed out i have noticed them on my R4. Will try to lift them up.
I was thinking to repair it for yellow one (https://www.renault4.co.uk/forum/threads/what-have-we-done-this-time-r4-f4.10408/#post-71842) but it is so badly rotten that it would be to much job for me.
Especially as i have never ever velded anything.
BorgeB and i take off floor and it is rotten inside crossmembers.
I am thinking to make it my "lab rat" but do not know when i could do that in day.
Do you need something from chassis?
Yes I need the right front side member (77 00 579 477) provided that it's not rusted.
For the C-pillar finishers, let me know if they come off intact.
Hi Angel!
Sorry for delay.
been at chassis location and took some pictures.
Chassis upside down
Unfortunately right front side member is in worse condition than left one.
Right side
I have open it to see situation inside
Left side
If you think it is usable to you let me know and i will cut it off.
No, they are "HS" , to borrow a little French vocabulary :-)
