Hi Guy's
need some advise on carb set up, i have searched but my question relates to mixture. i couldn't find the answer i was looking for so here i am..
not sure what carb i have yet, but i have a r4 gtl year is 1988 and its left hand drive.
the paperwork i have say's its 1108cc
my question is: I found this answer in the similar posts below, my bad did not no they were there.
does the mixture screwing in (clockwise) richen or weaken the mixture. as i want to see if i can lean it off a bit at a time to get the bet out of her.
when i received the car it was revving around 2000 rpm at a guess and the idle screw was at its minimum, the mixture was 3.5 turns out, so have set that to 1.5 turn out. the result is a better idle speed.
also i have set the timing up atm to centre as suggested for running leaded fuel. please correct me if thats wrong.
it was a game of cat and mouse adjusting the distributor and idle to line it up, but after a trip the the courier up some good hills i heard no pinking.
from what i've read i need to clean and check the ignition system too.
thanks very much in advance for ideas and suggestions, and sorry for this long post.
