Thanks Steve for all your time and info.
I did email the Carb exchange as I thought it would be easier and the opton on their site was there. I buy most things from eBay.UK/USA as I find it a lot easier as where I live most things seem hard to get (even ordinary things) and even if I do find them, they are normally a lot more expensive in France (even with the postage).
When the kit arrives I will change all the parts and fit new gaskets and a bit of hylomar on the base gaskets as you said. I presume the mixture screw O-ring is in the kit (it looks like it rom the photo)?
In the meantime I'll check the compression and valve clearances but have never done this before (but am quite able and whould not do anything without first researching it in books/internet) - My dad will be over tommorrow who is an ex car, bike and Tank mechanic so he should be able too do these tests in a flash
Yes, I read that you increased the size of your main jet by 0.1mm !! in another post.
I was thinking of buying a compression test kit - anything to look out for when choosing (I don't want to spend a fortune) - have seen them for £10-£15 on you know where:wink
Regarding the gearbox seals I mentioned in a previous post - I have been to Renault and they said that they were unable to get them - even from the main Renault manufacture and that they were considered as a DEAD stock!
I have found them on the Franzose site (it's a really good site) - the dimensions are 36x54x7.5 aren't they? They don't have the O-rings but if they are 104X3mm I have tracked some of these down too in Nitrile rubber in the states.
Cheers Steve
