hello,
I tried to start my R4 this morning, but the engine did not start. After opening the carburettor from above you can see a hole. I *think* I remember that you could actually see the fuel coming in from there when someone else tried to start the engine but I am not sure.
I have not been able to see anything this time (while someone else tried to start the engine). So does this mean that the fuel does not reach the carburettor? Or is it normal that you can not see it?
I then pulled out the hose from the outgoing side of the fuel filter (the engine not running of course) and quite some fuel was propelled out of it as if it had been under pressure. Is that normal? I then tried to start the engine and saw fuel come through the filter, so that at least is working.
Any help is appreciated.
