harbourseal
Renault R4 Lunatic
- Breda The Netherlands
Hi All,
I ran into a slight problem.
The 1400cc engine I rebuild was blocked after the assembly.
Not having time and energy to investigate what was wrong I left the engine alone until today.
I took of the sump and undid the crankshaft bearings and the connecting-rods.
And hey presto, the engine turned round without any problems. The new piston rings give some resistance but it is turning round.
Then I tightened the crankshaft bearings and torqued them. The engine was still turning.
So It must have been the connecting-rod bearings. I torqued them to 30Nm and all was ok. But my workshop manual says it must be 40Nm
Can anyone Shed a light on the right amount of torque needed for this engine. Because 40Nm is to much. It blocks the connecting-rods on the crankshaf.
Needless to say that I used the original bearings and I kept them in the right place and marked the liners and pistons to keep them in the right order.
There was no excessive wear on all the bearings. I replaced the piston rings because there was some wear in the liners. After honing them the machine shop told me to replace the rings.
Your input would be greatly appreciated.
