(Quote) "There's no such thing as a stupid question" from my C.O. in the Army MANY years ago.....
If you're adding to a car & you're topping it up, buy some blue anti-freeze & some de-ionised (distilled) water & mix them 50/50, then use this to top up the system. You'll know that you're adding the correct concentration, thus improving on whatever is already in the car. If you're completely flushing the system you can flush it with ordinary tap water, tighten the drain taps, fill it with tap water and run the engine for about 15 minutes & drain it again. This will shift any crud and will give you an idea as to how clogged up the system is. In extremis a mixture of 10% bicabonate of soda solution can be added to the water and the engine run again for 15 minutes, before thoroughly flushing the system. Once the system is clear of debris, mix up the 50/50 solution of anti-freeze and de-ionised water and top up the system. Start the engine & let it idle-no faster-and open the bleed valves until liquid runs freely. A good trick is to hang the expansion tank high up on the bonnet, using a wire coat hanger, assist the air bleeding.
There's much more in this vein but that's enough for the moment!
Good luck!
