Y yanivalon Enthusiast Messages 30 Location Israel Jan 28, 2023 #1 I have new Dellorto frd 32d and I don’t know how to assemble it. It have 2 lines for fuel and doesn’t have vacuum pipe. Does anyone know how to connect it properly?
angel Enthusiast Messages 2,448 Location Athens, Greece Jan 30, 2023 #2 Fuel lines: one should be fuel supply, other is return which should be plugged. You have to make a T-piece and use the inlet manifold fitting for oil vapour recirculation as vacuum source for ignition distributor.
Y yanivalon Enthusiast Messages 30 Location Israel Feb 11, 2023 #3 angel said: Fuel lines: one should be fuel supply, other is return which should be plugged. You have to make a T-piece and use the inlet manifold fitting for oil vapour recirculation as vacuum source for ignition distributor. Click to expand... Thank you for your help
