Just running over a few issues with my new 86 R4 - fan not switching on, suspect radiator sender unit faulty. If so, where would I get a replacement?
Second, slight imbalance on front brakes (24%), so had a little nosey - brakes are Girling discs. Only fault seemed to be sticking lower plunger (whatever it is called!) caused by rubber sleeve slipping up the shaft when fitted and causing very tight movement. I gather Girling are no more - so how do I obtain spares? Could just the rubber sleeve be replaced? Anyone experienced this sort of prob before?
Thanks!
Thanks!
