My fuel pump on my R4 has had a leak for some time and eventually I got around to getting a new pump.
Today I set about fitting the pump and was most perplexed when I removed it. The engine side of things is a nobble that moves up and down against the fuel pump that has a seasaw type arrangement at its mating surface to the engine which pumps the pump. I was expecting a hole in which to slide in the arm from the pump.
I have looked through Haynes and can find no referance to this type of pump and or fuel pump presentation on the engine itself.
Is there another type of pump available for the R4 that does not have an arm that is moved up and down, but is pumped by a nobble from the engine that goes into the pump.
I am wondering if my engine is infact an R4 now! The pump installed has Sofabex on it.
Any advice would be great as I dont know what pump now to get for the car.
Cheers Yellowvan
Just got a pic, what do you think, you can see the engine on the right and the pump on the left.
Cheers Yellowvan
