Hi all
I have a 1968/9 R4 with welded hinges and split dowels, removal of the plastic cap (cover) is no problem BUT how do you get the pins out? They seem incredibly tight, is there some secret method? I'm afraid of damaging the door/hinge
you have to use a dovel to knock out the inner one first,then the outer one,(they are one inside the other)they are split along lenght and can be tight,use some WD40 etc first... -Reid.
