Drive shaft outer CV joint Rubber boot problem ?
Cyprusnoddycar
Cyprus EU
I was fitting my new drive shafts today, and everything was going well until I noticed that the clips on the outer drive shaft CV joint rubber boots are touching the lower steering arms ? So I guess the new reproduction Upper/Lower steering joint tapers are incorrect and going in too far ? I flattened off the clip as much as possible, but it still fouls the arm, when turning the steering. The only way I can see around it is to make 'Dent' in the top of the lower arms with a large 'Ball peen' hammer to make the clearance ? Has anybody else had this problem before ? Thanks Kevin20240210_114105.jpg20240210_144015.jpg
I've had the self same problem. Some bottom steering joints are too long, and while it's fine when the car is on it's wheels, as soon as you jack it up the boot clip fouls the bottom arm. The problem arises when the car goes for its MOT. You must make sure the tester is aware of this and hopefully they will make allowances. Otherwise when they spin the wheel to check the wheel bearings it will quite literally rip the boot off. Better to fit some shorter bottom joints.
I've had the self same problem. Some bottom steering joints are too long, and while it's fine when the car is on it's wheels, as soon as you jack it up the boot clip fouls the bottom arm. The problem arises when the car goes for its MOT. You must make sure the tester is aware of this and hopefully will make allowances. If not fit some shorter bottom joints.
Many thanks for this useful information, I thought it was my mistake at first. I will try it with the wheels back on tomorrow. I have found some other repro R4 parts a bit suspect as well. Think I will try and find some original lower steering joints over here. Cheers Kevin
You are very welcome Kevin, and good idea, new old stock is always good if you can find it.
Kind regards Bry
Yes, I think I know an old motor shop with some R4 new old stock. Will investigate. Hope you are keeping those 'Emmets' out of Cornwall ! LOL !
I've run into the same trouble. I was fortunate to find an old stock driveshaft but these aren't going to be available for ever.
It's a bad design - there isn't enough clearance between the driveshaft boot and the wishbone. Add to that a replacement ball joint and the clearance might be less. Add to that a replacement driveshaft boot (the original driveshaft boot clips were really slim) and there is trouble.
I've not found replacement ball joints or replacement driveshaft boots that improve the issue. If anyone has found any it's worth noting the manufacturer/ supplier down on here to save others issues.
A dent in the lower arm might be a good idea (apart from all the structural integrity stuff). Can't recommend it but lower arms are not known for falling in half so it's probably something I might think about in the future.
Thanks for all this info Malcolm, think I will look for some thinner metal drive shaft clips first, as the problem is where the thicker 'Clip joint' is causing the main problem.
I just found these thinner S/S clips in one of my boxes of bit and pieces. So will try them out today. Thanks again for your help.20240211_075614.jpg
I think your problem is more related to the outer CV joints being larger in diameter than factory ones.
Yes, I thought that was the problem as well.
But the good news is that I have now fixed the problem, by removing those thick clips and fitting the thin S/S clips like Malcolm said. So the shafts now have about 6mm-8mm clearance to turn with the car jacked up.
I am usimg thi kind of clips for boots
Berner is not only one that sell this kind of clips.
Good thing is theay are self locking.
Once you pass end of clips throught head of clips you can not open it again.
Rest simply cut with pliers or brake bending it back and fort few times
They should do the job hopefully.
Hi, many thaks guys, finally i had time to take out drive shaf(s) and lower ball joint(all joints actually ) and it was surpricingly easy to do even my garage was reserved by my wife with old junks for two years, so i had to manage outside under terazza roof.
All details went exactly as descriped here in several stories, lift the car on jacks, take out wheels, loosen drive shaft nuts and hit it slightly to loosen the drive shaft from brake drum, purchase cheap ball joint splitter(only 11,99Eur), loosen ball joint nuts slighly and split it, use jack under the wish bone to get the ball joint to a normal position, use angle grinder to cut two of the lower ball joint bolts because the bolt are rusted and the nuts just wont turn(actually again funny Renault base ide to use different sigzes of nuts, one was 11 or 12mm's which did come off and two remaining 10mm's).
Clementine himself describes on tech tips for lower ball joints repair that "The front balljoint is one of the trickier jobs to do at home. You'll need a ball joint splitter, and probably an angle grinder. And of course the right joint to use as a replacement."
Time flies but as you might see form the bill,. parts were purchase 10 years ago...
Brake drum after brushing&paint, taken out drive shaft and broken rubbers..to be changed
I have been down this route and the problem is caused or exaggerated by replacement front shock absorber being too long allowing lower arm to droop too far
Genuine Renault shocks have stiffer rubber bushes and approx 10mm shorter
Somewhere in the midst of time I have posted about this B4
Hi, i.ve tried hard and harder but no succeeded to expand replacement rubber ower the outer shaft end, this rubber has no loose rubber ring as the old one but thicker rubber neck on the smaller diameter.What to do, i tried with oil and warm with water, should i heat the rubber or what?
Hi! -you might try placing the rubberbooth in the micro-oven as it should get softer that way. Prepare b4-hand so you can slip it over quick as possible..
Ok, thanks, have been using a heat gun and it helps some, i added one wrench socket to the end of the guiding pipe and now i am on the half way. Must admit that its a grazy job.
