Dropped door fix?
paule78
Newcastle upon Tyne, UK
Is there a fix or repair kit for a dropped drivers door on a 1981 TL? The hinge is the style with the nut.
Is there a shim or bush that can be fitted?
I always used to open the door a little then give it a pull upwards to bend the hinge back to the right place.
Thanks.
I can see slop in the pin holding the door … maybe a thin shim or large bolt … then a bend?
how's about you stop leaning heavily on that door looking Cool as H*ll ? -Reid :whistle:
