Electronic Rev Counter installation
Tomcat
Milton Keynes
#1
Getting very frustrated trying to install a 52mm electronic rev counter on my second F4 with a 1108cc Cleon engine.
Have one fitted on first F4 with a 845cc Billancourt engine which works well.
Three wires - Green to negative on coil; Red to Ignition switch and Black to earth. Have checked all connections etc., with no joy at all.
Anyone offer any ideas please? Thanks
Newington
#2
All sounds correct but you may find that the tachometer itself is a dud, I had one that read too low so I wouldn't be surprised if one was faulty entirely.
You could try it on other vehicle and see if it works then.
Tomcat
Milton Keynes
#3
This is a second one I am using. Both new. Thought first may have been a dud but 2 more unlikely.
angel
Athens, Greece
#4
Is the negative terminal of the coil actually connected to the contact points?
laxeian
Galicia
#6
Hi Tomcat,
Recently fitted a Gammatronix onto the ignition system on my F6, modern system, old car, would think the basic principle of how the Gammatronix works would be similar to the pick up for a modern rev counter, on the coil the pick up is on the + terminal of coil, the negative being earth,
Have you tried disconnecting rev counter from negative terminal and connecting to the positive coil terminal, this side it would see the pulse ( on / off ) of the points ( think this is where angel was pointing )
Tomcat
Milton Keynes
#7
Hi Tomcat,
Have you tried disconnecting rev counter from negative terminal and connecting to the positive coil terminal, this side it would see the pulse ( on / off ) of the points ( think this is where Angel was pointing )
OK understood. System works as I described on F4 No 1 so I did not see going from 845 to an 1108 would change things.
Will try what you suggest. Thank you.
mr-reno-139
AKA Paul Cunningham
lancing west sussex england
#9
I had a Peugeot j7 camper run baddly
Recently
disconnect faulty tacho perfect now
angel
Athens, Greece
#10
What I was meaning, and what perhaps your problem was, is that someone may had connected the coil the wrong way round (+ terminal on the points, - terminal on +12v ignition feed). Your engine would had been running just as happily as ignition coils don't have polarity (almost-it's the center electrode of the spark plug that wears now) but when you connect the tachometer to the (-) coil terminal it's not feeling ignition pulses, but rather continuous +12V.
Tomcat
Milton Keynes
#11
Angel. Thank you for your explanation. Appreciated
Domsky
GLANWORTH republic of Ireland
#12
I now have 1 working rev counter by swapping the green feed to the +ve on the coil. Thanks "angel" & "laxeian".
Hi , how did you mount it ? Can you post picture how it looks inside , and maybe link where to buy it ?
Tomcat
Milton Keynes
#13
Hi there
I have mounted mine in a gauge pod that I got from Vehicle Wiring Products.
Rev counter itself I got from ebay but you could go to Demon Tweeks; Merlinsport etc. Depends how much one wants to spend.
I have mounted mine just by the door as shown in attached picture.
One could use a gauge bracket instead.
Hope this of some help.
Tom
Domsky
#14
Hi there
Tom
Thank, i will be trying to find something that looks more old school :)
