Hello all,
Sorry in advance for any 'elementary' questions, my mechanical knowledge is limited but getting slowly better.
I have a Renault 4 TL from 1982. Type R1126. It is time to change the belts and wondered if anyone knew exactly how to do this as the Haynes manual isnt very explicite nor have I found any good advice on the internet.
From what it appears, the fan/alternator belt is a lot easier to get to than the second belt (drive belt?) which I presume drives the fan and the alternator belt.
Does one have to remove the radiator to change these two belts? I don't see how this can be done otherwise. Can I just move the radiator forward a few centimetres to get the two belts out (So the belt can slide in between the connection from the engine to the fan)? Seems a bit overkill to drain the radiator and remove it entirely just ot change the belts!
It doesnt appear as though the two belts are the same size. Is this true? I currently have 2 replacement belts of this model GATES Courroie trapézoïdale - 6280MC (AVX10 x 688La) which on analysis seems to correspond to the alternator belt which seems slightly larger than the drive belt.
Any advice would be greatly appreciated and thanks!!
