Flexibles
bison
Hello Gents,
Any idea where to buy flexible front brake pipes for a drum braked TL 1977?. I see some rear ones on Ebay but no fronts.
Thanks,
Alan.
bison! you might find them as 'universals' in various lenghts with correct unions & banjo-fittings in just about any accessory-shop..
Or shop can order the correct ones from aftermarked suppliers to fit your drive
-When you mount them be sure to twist them in the correct direction as they will bend in the middle when in use! -R.
Alan, no need for universal hoses as the correct ones are available from your local accessory shop who deal in Quinton Hazel parts. You need two of BFH 4217.
Steve
rear flexis
Steve, you gave Bison the part number for the front brake flexi pipes.
Would you happen to have the part number for the rears?
Its for the same year Dec 1975.
David.
