As David says, it'll be like sucking through a very small straw instead of a hose pipe.
The engines fuel pump and carburettor and the rest of the fuel system will have been designed as one piece, so changing the fuel pipe for a smaller diameter will make it harder for the fuel to reach the parts its needed to be.
Your local car accessory shop will have the pipe in copper in the correct diameters get yourself down there and buy the right one.
Oh and don't forget to take the rubber hoses off the old pipes and reuse or replace if needs be, otherwise they won't fit back into the clips and will be lacking the protection in places like the front wheel arch.
