Hi New to the board so hello to everyone, hope someone can help, i have the fuel pump with the pin that operates off the cam and then onto the pump lever. i have removed the pump and checked that it works by hand and it does with approx 5mm play before you can feel the lever push up against the spring and start pumping (i have done this with fuel and this gets a good jet comming out) but when back on the car there is no suction it is almost as if the pin is too short or possibly excess wear on the lever and therefore not pushing the lever far enough to activate the pump.
the car has been sat for a couple of years but was running up to that point so not sure that the excess wear issue is correct,
any ideas on this would be greatly received
