Just had to take mine out as the fuel pipe from the sender unit split and its above the tank.
Remove the rear wheel next to the filler pipe and support the car on stands.
Remove the clip on the filler neck and loosen the joint, also disconnect the breather pipe.
Then remove the two bolts (18mm)for the spare wheel bracket/hanger, then remove 4 (11mm) bolts on the crossmember that the tank sits on , then the one in the boot floor was 13mm and you need a long reach socket for that one underneath the car.
Remove the crossmember from the tank with 3 bolts.
I also had to remove the mud flap on that side of the car to allow the filler neck to slide back when you lift the tank over the roll bars.
When the tank moves back disconnect the wire to the sender unit and the fuel line before you remove the tank.
I tried to use the drain plug to empty the fuel ( an allen key ) but it sheared off and now and I need to get the drain plug (alluminium with a steel plug !! ) soldered back into the bottom of the tank
All that work for a fuel pipe
Now I just have to put it all back together again tomorrow
