mojobaby
Hello everyone, my problem started a few weeks ago with a knocking in the engine when I accelerated or went up a steep hill.
At first I thought it was my new drive shafts which I had just installed. After taking them out and putting them back a few times I realised it wasn't that.
I eventually traced the problem to the bush in the upper wishbone suspension. The bush was completely worn out.
At the same time I discovered that the support strut that goes from the engine mount to the block was missing. Thanks for the tip David M
I eventually found a second hand one on Le Bon Coin and only paid 10Euro for it. I just had to clean it up and repaint it.
Unfortunately, it doesn't fit correctly. It seems that my whole engine is too low by about 1cm.
I think it might be my engine mounts as the rubber is flat and perished, so I have ordered new ones which will arrive next week.
I've decided to take the whole engine out as well for a good clean(started already) ,so if anyone needs photos of parts in difficult places, let me know
