Cyprus Andy
- Troodos Mountains Cyprus
Hi has anyone any idea how I can re tighten the handbrake lever to the body ? It was like this when I bought the car and thought it would be an easy fix but I cannot see where the bolts are located?
it has come loose on the front 2 bolts and they will not tighten but they are not visible in the engine bay so where is the back of the bolts located ?? Got me puzzled !
Is there anything behind where the bracket mounts that I can get to to fix it or if there is nothing behind the panel can I just zip it with the Mig welder to re attach it ? without setting anything on fire or melting any wire's in the loom ?
ops:
I suppose I will have to strip it then don't fancy a fire from the foam:eek:........hey ho everyday a new job to doo_O cheers Malcolm just glad you knew what was behind it
