Head Gasket and 14mm socket
isle of wight
#1
I'm after special 14mm socket tool and extension Renault part number mot-23-12-384 plus head gasket and rocker cover gasket along with 8cm long rt angle bend 1 cm diameter heater hose (between water pump and junction with rest of heater hoses). 1986 LH R4 Engine no 6410 658841 845cc. I'm trying all Renault Part sites but nothing back yet? Any recommendations? Tim Bristow 01983 875378
reidalpine
#2
Tim-
The right angle Dia.1cm bent hose is easy to make yourself,buy the right diam and lenght rubber-hose(Halfords etc),to keep it angled,without
kinking it or ending with a flat-spot in the bend just put a 3mm.wire inside it ,bend it and leave wire in there. Rocker cover gasket and head gasket is offered by amongst others Der Franzose/MelunRetroPassion (both on ebay)or own sites.. -Reid.
mr-reno-139
AKA Paul Cunningham
lancing west sussex england
#5
you don't need special socket unscrew pushrod adjusting screw s and slide sideways remove pushrod revolve rocker upside down use normal 3/8 drive socket
learned this one 40 years ago
