petak
- Vodice, Croatia
Hi to all!
I an in middle of a problem here!
I had a plan to clean all suspension part to the bear metal and take them to hot-dip galvanizing and to powder coating.
But front suspension lower arm is hollow, and it is unreachable with drill or grinder.
Not sure if even sand blasting could reach inside.
Here are some photos to give you closer idea of my problem.
Hole below ball join on lower arm that goes all the way to the bushing on other end of lower arm. Torsion strut goes in here.
Rear end of front lower arm
From one end to the other there is some 35-40cm (do not know right dimension)
Does anyone here know how to clean inside front lower arm to the bear metal?
So that it will be prepared for hot-dip galvanizing!
Thank you for reading
