I have just removed the distributor from the engine to replace the points. After fitting the new ones and properly timing the engine, it will not start. With the ignition on and the points closed, when they are manually opened there should be a small spark but there is not. Also checking with a voltmeter, there is 12v all through the points system even when the points are open. I must have a short somwhere. Any thoughts?
Cheers
Cheers
