Ignition switch wiring
Tomcat
Milton Keynes
I am trying to sort out which wire to connect to for using accessories that will switch off when ignition is off.
Have 'borrowed' this picture from Media to show the 5 wire arrangement. This is what I believe I have.
Can anyone clarify which I should connect to please?
There should be some spare fused connections in the fusebox. I normally connect to one of them with a spade terminal rather than splice into the ignition switch wires.
Malcolm, Thank you for your comment.
I am obviously looking for a connection that will only come on when the ignition is on.
Pictures attached of my fusebox.
Any recommendation from experience? I am sorting my way through which fuse serves which circuit, or circuits.DSC08942.JPG DSC08940.JPG
Glad that helps Tom. This information came from a handbook, the type that would have come with the car when it was new. I was lucky enough to get my hands on this one through the Renault Owners Club a while back. I think it was the last one they had, but eBay is always worth a try. Maybe someone on the forum has a spare one they could let you have.
I'm no expert on car electrics but I recently fitted some extra instruments and a couple of 12volt sockets. I took the feed from No 1 terminal, but made sure it was the fused side. So far so good, no smoke!!
The handbook given to me with the van was for a very early model and did not have the diagram you posted.
I am at present preparing a sheet regarding the fusebox.
I agree that terminal one appears the one I would use for a new feed location.
More later.
R4F4fusebox_0001.jpg No sooner the word than the deed!
Attached is a sheet I have prepared for just the fusebox area.
Based on information from Haynes Manual, observation of my box and page from Renault manual above.
I am not 100% sure of all the colours listed. Maybe tracer colours so fine not easily recognised.
Any comments, corrections are welcome
At my blue 4, the push button sends power to the starter motor.
how to restore to factory settings?
