Rich
Indicators / hazard lights /horn stopped working!
I have changed fuse and relay. Cleaned earths, checked with separate power to indicator bulb ( from side lights) indicator bulbs light up so earth good. Cleaned terminal on horn, horn started working.
There's power at the hazard switch. There is power at the relay when hazard switch on and/ or ignition switched on. There is 12v across no. 9 fuse when hazzard switched on with and without ignition on. There is nothing across no. 9 fuse when ignition on and indicator arm middle, left or right.
There is constant power at the indicator switch.
There is no power at the indicator bulbs.
Is the indicator arm kaput or a bad earth or have I missed something?
Rich
Rich
