it look bad but its mine! (restoration process)
even the iron pipe was melted by rust!
l buy new pipe
l start to replace the new pipe and l test to drive my R4 to check if there is any leak again, there is no leak.
i finish my work without any help of mechanics,
work finish.....
Did you changed whole fuel line or just front part?
It is hard to get to fuel sender in fuel tank, and it is tricky to access fuel line on side cross-members
Hope that all your fingers are well!;)
Jambo! l only change the sturbon place which is near the tire, to change the whole fuel line is difficult especially start from fuel tank
after change the fuel pipe i drive my car bt i start notice a loose of power and miss! but if u use a lot of fuel it have no problem, my mechanics told me is plug problem.........
he remove those plug and say they are not spark. they are supposed to be change! and this is second time i change them,:mad::mad::mad::mad:
my mechanics tel me to go ti bosch dealers they have original parts.
am plan to go to bosch dealers at noon! to check those plug and advice me which one to install
it was noon l decided to go bosch dealers to check those plugs
They give me this short range plug which is best for my car
l got accident this morning when l went to planting trees at kibola spring............. my tyre bust, uwiii:mad::mad: there is no other option rather than buy new tyre!!
the arrow show the place which cut my tyre.
some pic of my project of planting trees from y'day friday and today morning....when l was at kibola spring....
another pic!
Helow all, i saw a leak of break fluid in my tyre, l decided to call mechanic and open tyre and drum
The arrow show the leak of brake fluid which reach up to the ground
1. it was rubber which cause the leak of fluid
2. The new rubber which l buy!!
1.We remove all bearing, and wash them and put new grease!
2.The pic show restoration of all parts! everything is clear now........ no more break fluid leak
when you see this pic you will notice there is another problem!!! the muffler is finished:mad:
l supposed to put new muffler
