Help !
Can anybody give me any suggestions about where to start looking ?
We have a 1986 1.1 GTL, which runs brilliantly - normally. The problem we have is that every so often, but not on every trip, the car suddenly just cuts out completely. If you pull over and wait, it will restart after a minute or two.
It does this when it is cold or hot.
The motor runs without any hickups. I have replaced points, plugs, leads, dizzi cap and rotor arm, coil and fitted Boyer Bransden ignition.
I have tried wiggling all the under bonnet cables to see if I can find a loose connection, but to no avail.
My two thoughts are that it's maybe a bad connection in the ignition switch on the steering column, or something completely different - a sporadic problem with the fuel pump.
Can any one help who may have had similar problems.
As the breakdown only occurs now and then it's not the sort of thing you can take to a garage (very last resort) as I just know it will not perform the problem when I want it to.
All suggestions welcome.
