low rear brake pressure
iain250
hi folks just got round to putting our gtl on the road again only for her to fail on low brake pressure on 1 rear side ( pretty good considering shes been under a cover for 10 months ) - any short cuts or will i strip her right down on both sides
thanks
iain
Open bleedvalve to check if there'e pressure in the system -when stepping on the brakepedal Look for gunk or "foreign-stuff" plus air-bubbles-if any bleed system.
Take offending side wheel and brakedrum off to see there's (enough)movement in the wheelcylider-pistons,as in my opinion they are the first thing to cock up when car is sitting still for any lenght of time.They are cheap and easy to locate so if in doubt get a new one
pump all brakefluid through and replace with fresh & waterfree stuff!
If car sits still, remember to pump the pedal once in a while to avoid it getting stuck............... -R.
Low brake pressure is an MOT word for brake not effective enough, rather than anything to do with pressure inside the system. There's no real option other than taking off the drums and having a look at the brakes.
Leaky rear wheel cylinders are common. They contaminate the shoe and ultimately make it fall apart. Should be obvious when you pull the hub off.
In the old days we always had a problem getting rear brakes to pass the MOT if the tester didn't understand that with no weight on the back of a R4 you don't need much pressure.
After checking they were in good order we would take the car back for test with 2 5gallon barrels in the boot,
The MOT seems a bit more forgiving these days. In the past I was failed for all sorts of things, but these days the focus seems to be on if things work and what's going to happen if any non-perfect bit breaks. They have the advise to protect themselves (I consider that a fail that I am allowed to sort without having to bother going back for a re-test).
It's handy to have the 50 minute time for tests. R4s don't take anywhere near that to check, and with the Gordini we used the spare time on the brake machine to set up the rear brake proportioning valve a bit better - new one on that and it was way off adjustment (though not relevant to the earlier question which was difference between rear brakes).
thanks lads - stripped her down tonight - yip rear cylinder looked fine but pulled back the dust covers and its a mess luckily the cover has kept it all in one place il get new cylinder and sort out - must say the rear brakes are a credit to her previous owner - looks like he knew what he was doing.
