- Bedford UK
It's not really a R4 :smile:, it's the MGA I have fitted with a 1950cc tuned and fiddled with MGB engine.
I changed the head gasket last year because of a big oil leak from the rear of the engine. That fixed it, but it's back again after 300 miles. There are no other head gasket problems at all, just a leak from the oil feed to the rocker gear at the rear of the engine leaking through the head gasket.
I think the oil pump/relief spring might be the "uprated" ones as oil pressure is 70psi on the gauge.
I'm guessing pull the head off again and getting the block and head checked for flatness would be the way forward (or alternatively fit an oil catch tray). Has anyone come across this sort of thing before? I've had had head trouble in the past but never just an annoying oil leak - the engine seems fine otherwise.
For a bonus point, are cold plugs any use for tackling pinking at 2000rpm at light to medium throttle? Both the MG and the Gordini are a bit sensitive.
