trichens
- Barton Upon Humber - United Kingdom
Well... not really missing but certainly hard to find.
Basically when trying to get reverse gear I usually end up in 4th - I get reverse about 1 time in 5 - which can be embarassing.
Is there a known problem with the 4 speed HA0 gearbox?
Does this indicate an issue that I should be worried about?
As this is in a DRK, the gearlever coming out of the gearbox is S shaped to bring the top end further back (and I suspect the nylon grommet sits a bit lower).
Equally, as it's only 440kg I can push it backwards when I can't get reverse
