Need help with engine mounts
Bflorian
Serbia
I was planning on taking out the engine from my R4 GTL but i cannot access the bolts to the engine mount, its just placed so weirdly, theres nothing really in the way, the gearbox is out, the radiator, everything is out, how do i remove those mount, or just unscrew them?
Unscrew single nut under rubber part of engine mount where it sits on chassis.
RUbber mount 4 bolts that are placed on engine block you can remove when engine is out of the car. And they are tricky to remove when engine is in carRT40414.jpg
Okay, than you, but i already know that much, but how do i access the bolt? My socket isnt long enough and my ratchet too, but if i use an extension that because of that i cant, must I be under the car to access them properly?
You need to.use long tubelike socket and extension.
And must be under the car to get proper perspective .
