Hi everyone,
Looking for a bit of a sanity check.
I have an '84 F6. Got it running a couple of months ago with a couple of wires and switches to simulate the ignition switch (no keys). I have now replaced the igntion barrel but It won't start.
Standard 1108cc engine, no visible modifications. 120psi across all 4 cylinders. Ducellier R324C33 distributor. Fully charged battery. I dropped the tank to replace sender unit and fresh fuel (not spark related I know)
I am testing for spark by removing plug with HT lead attached and grounding to distributor mounting stud (which has continuity to battery -ve terminal)
So far I have:
Replaced ancient coil with new Accuspark part.
Replaced points, condenser, rotor arm, cap, spark plugs and HT leads with new items.
Bypassed the ignition circuit part of ignition switch with direct lead from battery to distributor +ve terminal to rule out short somewhere.
-ve coil terminal goes to screw terminal on distributor. Condensor also connects to this terminal and obviously is secured to distributor housing.
points gap is 0.4mm.
Points appear to be opening and closing - metered to test continuity from points "arm" and the terminal on the outside of the distributor - open until points close then circuit is closed.
I have also tried a known working, non ballast coil from one of my minis and the same situation.
The distributor body has not been moved or rotated.
No spark and the frustration is building.
Can anybody offer any more tests or perhaps highlight something I have fogotton please?
So far I have:
