Andy McGhee
- Cheltenham
Hi all
I recently (2,000 miles ago) replaced the head on my F6 van, which had then done 172,000 miles. There was clearly something wrong with the original head; the van lacked power and I suspected there was a valve problem. When I removed the head, I saw immediately what the problem was - one of the exhaust valve seats had receded so far into the head that the valve had burnt badly.
Anyway, I fitted a good second-hand head, ran the van for 500 miles and then retorqued the head bolts; everything seemed fine for the next 1,500 miles. However, yesterday I noticed that the coolant level in the expansion bottle had dropped, and (more worryingly) that there was a little oil in the coolant. There are no overheating issues, no bubbles in the coolant, no sludge on the oil filler cap and no water on the dipstick. I retorqued the bolts this morning and rechecked the valve clearances.
I replaced the head on my GTL 50,000 miles ago - absolutely no problems since then - and followed the same procedure with the van. I was careful not to disturb the liners, and cleaned out the head bolt holes (I suppose one or two drops of oil might have got into the coolant while the head was off, though!). The new head wasn't skimmed, but I checked it pretty carefully with a straight edge.
Would really appreciate your advice on this.
Andy
Andy
