lazyduck15
I just recently joined this forum and I enjoy it. I was surfing in the net for R4 info and I believe this is the one for it. Thank you for your acceptance.
I purchased two R4 in February this year here in a small city near mexico city, where just to be a Renault factory back in the 80`s.
They are 1970 and 1971,One is 845 cc the other one I do not really know as the engine does not have identification and in general this car seems to have several changes on it.
Both engines are leaking oil, apparently trough the carter`s gasket. They really through away the oil at a crazy rate.
The first question being what would be the reason for the leak, a fatal syntom?
or this is just a matter of changing the gasket, at least for the mean time. If such is the case, is it possible to remove the carter while the engine is in the car?
I have dismounted the roll bar and I can see a crossmember in the way of carter removal.
Is it safe to remove this crossmember
?, I have noticed it relates with the front suspension spring bars.
