Today I started to replace cylinder head gasket on my 1991 Savanne which I understand has a 950 engine.
However the gasket set from Franzose is different to the one fitted. The original has slightly oval 72 x74 MM
holes for the pistons, which Franzose tell me are usually fitted to the large 1100 engine.
Can anyone enlighten me which engine I should have.
The car has only covered 62 Kl and I assume it is all original and correct.
Did they produce late Savannes with 1100 cc engines?
PS there was little wrong with the car other then a slight oil leak which was the only advisory on the MOT and I wanted to avoid the same comments next week, when I take the car in for this years MOT.
