Radiator removal.
edwin
Lichfield
Hi all. there is a derelict '71 R4 near our place in France. Its tucked away bothering no one so a good chance its still there when I get back over.
It has an immaculate radiator, which I want. The car is upright, without wheels or back suspension. There is a chunk of log under it.
Can I take out the radiator from above, or do you have to get at those two bolts from underneath ? I couldn't get my fingers at them last time, but that may be just me. Any suggestions most welcome. Will look for other bits as well. Thank you.
I got caught out by this, years ago, when replacing a leaking radiator. The Haynes manual didn't mention anything about bolts underneath the radiator, so I drained the system, removed the pipes and supports only to find the radiator still wouldn't budge. Then I found that the bolts underneath required extra long sockets (requiring a long journey to buy them). Then I found the bolts were seized so had to call a mobile mechanic!
So the lesson for me was to ensure you can undo all the bolts before draining the system (and don't rely on Haynes!).
Would a 13mm slim ratcheting combination spanner be slightly easier to use? I think Edwin already has a set from Lidl. 13mm ratcheting combination spanner.jpg
Thank you all for your advice. If you are standing over the engine where do you insert your hand with spanner to get at those two bolts ? It would be dangerous for me to go underneath with the way the whole car is balanced on a log and no way or stuff about to prop it safely.
Instead of balancing your car on a log, use beer crates.
They have a multi function;
1. they are a sturdy support for your car
2. the beer is a thirst quencher.
3. invite friends for help and beer.
You hold the spanner at the back side of the steering rack (towards the bulkhead), holding its end over the nut with your other hand from the front side of the rack. Both nuts are undone the same way, left hand side one is trickier and you may need to flip the spanner in order to get to another flat. It also helps if you have a small 1/4" ratchet with a suitable extension to clear the rack.
I went back to the car and had another go and still could not get at the bolts in a way where i could put in the power to get the bolts to move. The car is perched on inappropriate bits and pieces and rocks around when you lean over the wing to get at those bolts, and your feet and lower legs are vulnearble to the car sliding off its support.
I did get two mats off the car and numerous bits and pieces. The alternator has a long bolt that supports it off the engine block, and the bolt was inserted from the fan belt end so even with the other two bolts out I could not remove the thing because the bolt was fouled by the pully wheel. I tried unbolting the support on the block but a bolt underneath was not removable because the whole care moved around too much.
When I am next there I will have a battery disc cutter and just cut through things and get the bits I want out .
As always, thanks everyone for your help and suggestions.
Hi all. Radiator update. Fellow forumist John came over to stay, clutching a stubby 13mm spanner. We applied WD40 to the bolts and a day later he was able to get the bolts off and hey presto the rad was liberated. It’s in very good condition so a useful item. Got the carb and other accessible bits as well. So thanks everyone.
