Removal of side windows
Brian
Leicester
hi does anyone know how to remove these please not the ones in the boot please
Brian
If it is GTL with plastic window frames easy.Look under the rubber inside the door and you will see some clips ,push these back to free the door frame and push out the window.
If an earlier car with metal windows more difficult as they are held in with screws inside the trim.More difficult as the screws at the bottom of the window tend to rust.
Unless the metal frames are in very good condition they are easily damaged when pushing them out.
I have a 1972 R4s and I want to replace the door windows with those from a 1982 GTL , is it possible and is there a video on youtube or anywhere else showing how it's done .
Cheers
