Hi all I am down in spain at present and have had a problem with my 1108 cc 8s basically the same engine as our R4s.
I stripped my head and found the head to be seriously damaged and some damage to the piston nearest the flywheel.
Opinion so far is that this damage has been caused by cheap lower grade fuel causing pre ignition.There is no apparent valve damage but I have not removed the valves yet.
The car is also fitted with electronic ignition which has been said could be contributing if it is faulty.
The lesson might be do not take the chance always add valvemaster + or a similar product to protect the engine.I will take a picture tomorrow unless anyone else has ideas
http://
http://
