Renaut R4/R5 Alpine Turbo 5.5x13 wheels Brand New available
r4allpourposes
Renault R5 Turbo Alpine Style Lightweight Alloy Wheels 5.5Jx13 ET25 3x130
We can provide Renault R5 Turbo Alpine Style Lightweight Alloy Wheels for Renault cars in silver polished finish with black inner painted. 5.5x13'', PCD 3x130, offset ET25, fits front and rear axle of Renault cars with 3 Stud wheels 3x130mm, like R4/R5/R6 etc... Provided with TUV certification. Tubeless wheels with warranty of 3 years.
Data Sheet
Condition: New
Weight: 5.3 Kg
Offset (ET): ET25
PCD: 3x130
They look great. How much including shipping to the UK? (For 4 wheels)
Sorry for my delay, but I forgot my password login. We can send to you 4 pcs. Renault Alpine 5.5x13 for Euro 524,00 with shipping included. We can also provide lug nuts for Euro 40 if needed (the original lug nuts don't work because they have flat head and here you have to use 60 degree conical nuts). For more info www.alfagiulia.eu or direct email 1300super@gmail.com
Not quite as straightforward as depending on what height suspension has been set at how stiff your shock absorbers and how well your wings fit and how you intend driving in my experience 165 65 13 should be fine but I did have 185 60 13 don't also forget that different tyres from different manufacturers the same size can vary diameter
FWIW I Bought a set of these some months back I think from Franzose and the recommended tyre size in the ad from memory was 155 70 13 but if you go on the their website you'll find it. Haven't fitted them yet got much bigger issues to sort out first so I can't tell you about fitment issues or post pics etc although with the suggested size I'm not expecting any problems. I would have liked to have gone a bit bigger if poss but decided to play it safe
Thanks a lot for this. It leads me on to another question, my shock absorbers are stiff, how do I loosen them? My car is higher than usual I believe, and I can't find anyone who can help me lower it, it runs fine but every pea I drive over makes the car shudder and potholes are a nightmare. Any recommendations on what to do will be appreciated.
I'm off to Le Mans Classic on Thursday in the 4L.
Wanting to look sporty, I finally stumped up for the maxilite alpine wheels.
I also invested in some new Girling front brake calibers: Lucas Girling Front Calipers
All went well until the garage went to fit the wheels...2 or 3 of the inner "spines" on the alpine rims rub on the front calipers.
We tried switching the wheels around, b ut the problem is consistent.
Is this a known issue?
Best solution? Spacers on the hub or.... careful use of a dremel!?
Its literally only a tolerance issue of 1-2mm, so it would not mean taking more than a tiny nick out of 3 of the splines that catch...
You can buy thin wheel spacers about 5mm thick. They won't affect the steering noticeably.
Thanks Malcom.
I've had a google and can't immediately find spacers.
Got a link, perchance?
Great firewall of china isn't being helpful. I guess search ebay for 3 stud wheel spacer and choose something thin. Most will have multiple holes for different numbers of studs and spacings.
Me I would grind metal off of calipers
Both wheels and calipers are likely to be reproduction and. Tolerance close but not 100%
If you had Bendix front setup loads more clearance to start with
