Kermit4
- Algarve,Portugal
Hi All,
The "new" R4 has been running great until yesterday when the engine would not run unless on full choke even when hot. Thought I would check the obvious causes and sure enough when I looked at the carb (Zenith model 28 IFP V05084) the tiny vacuum tube leading to the distributor had come loose at the carb end. Great thinks me and reattached it and checked the joints with the rubber pipes were all tight. Problem is the car runs exactly the same. Any suggestions as to why this is? Any ideas gratefully received.
