All, can you help?! I've got about a month to remedy the following symptoms exhibited by my R4 before heading off to Banjul on a charity expedition.
Symptoms:
1. Water/Oil mixture exiting exhaust.
2. Water/Oil mixture seeping onto front half of engine block, below the head gasket level.
3. Significant loss of water from cooling system.
Attempted fix to date has included replacing the head gasket (twice) which has seen no improvement.
On splitting the cylinder head/block we observed that one of the cylinder wet liners was proud compared to the other three and this one also has some movement whereas the others are firmly seated.
Reading a few web sites it seems that a bottom up strip and replacement of the cylinder liners may be required.
Is that your advice?
Has anyone got a better idea?
Has anyone got a donor engine?
All help much appreciated!
James
Symptoms:
James
