Rutger-peer
The restoring Dutchman.
Hi everyone,
I introduced myself just yesterday in the introduction-section, have been following many threads on this forum as well as Malcolm's guides and restorations.
I am going to restore my 1984 Renault 4 GTL from the 16th of June on and hope to finish it at least before half August (I have a long holiday so I can work on the car almost constantly) so I'm trying to get to know as much as I can before the actual work will begin so that I can avoid as much surprises as possible.
One of the things I am not really sure about yet is the paintjob. I am now trying to get the picture of the whole paintjob right in my head. I have been looking at how Malcolm (all of his projects on this site) and a few others did it but still have to decide how I will do it myself and I wondered if some of you guys could help me out or could give me some advice.
Here's the plan:
I plan to first remove all the paint till the whole car (both chassis and body) is bare metal and do the welding. Next I would paint the chassis myself since I will have a compressor at my disposal at the restoration site. As for the body, I'd like do all the preparations (applying primer etc.) for the final coating myself and have the final coating done at a professional paint shop, since I think I can never get that perfect finish myself.
That's the initial plan. What do you guys think of it?
Also I'd like to know what paints and primers to use (self-etching can't be used on sanded surfaces I read). Should I use the same primer for both the chassis and the body? And should I also use the stone-chip-primer on the chassis (what are your personal experiences with that since you used that Malcolm)?
Actually, I read a lot about it but there are a lot of different ways of doing the paintjob and I just don't know which way to go, so if anyone could help me out a bit, I'd appreciate that! Also, if anyone can tell me about the sequence of the whole process (applying primer, sanding, applying another layer etc.) that'd be very useful!
Sorry for posting such a lengthy message, I can never seem to keep it short
Regards,
Rutger.
PS: Would spraying tectyl on the downside of the chassis after it is painted substitute for not using stonechip primer?
Here's the plan:
Regards,
Rutger.
