Struggling with some parts
Elwood
South west
Hope someone can help, I am struggling with a few things at the moment. Currently still trying to see if a CV joint from a member here will fit my car. Hopefully this will be sorted in a few days. But there are other things I need. Wheel bearings and also a tie rod bush whatever that is. Problem is whenever I go to find stuff there seems to be so many variations. I'm wondering whether Renault changed parts every few months. Simple wheel bearings I thought would be simple are proving difficult. Mind you the stuff being made by the fella with the 3d printer look great for other plastic items. Where do I begin please?
Wheel bearings shouldn't be a problem Elwood. Remove the old bearings from the hub, large hammer and a punch should do it. You will see a number etched on the bearing. In your area you will probably have a company that supplies bearings and seals to engineering businesses and the like. They should be able to match new ones to those numbers. Don't forget the oil seals too.
