Hello,
after looking around for a bit to put a temperature guage on another car with a Renault engine in I found these dual contact sensors - one contact does the warning lamp as used on the 4 the other allows you to use temperature guage
I chose this one as I’ve a m14 thread, and want a warning at 110 C and have a 40 - 120 C guage to fit:
vdo-webshop.nl
saves looking around the engine for a second sensor port which mine didn’t have.
all the best Paul
VDO Coolant temperature sender 120°C - M14
VDO 323-803-001-008DTemperature range: +40 °C to +120 °CThread: M14 x 1.5Sender resistance range: 287.4 - 22.7 OhmSensor signal: 1-pole common groundWarning contact: 110 °C ± 3 °C
all the best Paul
