- Bedford UK
This doesn't have much to do with Renault 4s but maybe you guys can think of something I can't.
The problem is with my MGB V8. The engine starts and runs really sweetly with excellent power, idle etc. It's great until a couple of miles (long after the choke has gone in). Then it misses badly - not firing for a few turns and then picking up again. It seems temperature related - if I leave the car for a few hours it will normally be fine again. The problem seems to be getting worse.
I've tried plugging an ignition strobe in (one of the inductance ones that goes around the plug leads). Sure enough, periods of not firing correspond with no flashing of the strobe. That made me think it was ignition. It's a Mallory distributor. I've tried a spare coil, new leads, new cap, rotor arm, points, low tension wires, condensor, vac advance. I even tried an earth wire on the ignition base plate in case the earth was poor.
The carb has fuel in the float chambers. I did wonder whether it was flooding, but the car seemed just as bad with the fuel pump disconnected which ought to rule that one out. The symptoms are so similar to fuel starvation that I'm feeling fuel could be something to do with it. I wondered about vaporisation but the problem seems to happen before everything gets too hot, and it's not a town issue. It's a Weber 500 4 choke carb. I've had the top off and blown out the jets - it's all clean and filtered so I don't think it's dirt.
The engine itself is nearly new and has compression, good valves etc so I don't think the problem is mechanical. Besides, when it runs it runs perfectly.
I'm completely baffled. Has anyone had a problem just like fuel starvation that has turned out to be something else. I think the clue is it happens when the engine is warm, but not too hot. Any ideas would be much appreciated.
:clementi:
:clementi:
